LIGHTS
PRTZMAN55
04-22-2008 11:28:13
HELLO Its been a while since i have been able to get on the thread. I missed reading along with you guys. I hope may be you can help me, I put new 6v lights on my 200 farmall, rewired, cleaned all surfaces for ground ,new switch too. The lights actullay work but are dim is this a 6v thing or did i do something wrong , switch is new ,even put in a new battery. Any suggestions thanks Harry
chadd
04-22-2008 14:23:27
 Re: LIGHTS in reply to PRTZMAN55, 04-22-2008 11:28:13
Check the resistance at the wires, and across the fuse holder terminal. Also might want to check the battery and battery cable condition.
Janicholson
04-22-2008 13:54:35
if they came out of a box, the box may be marked 6v and the lights may be 12v. The bulb should have 6v right on the bulb, or a number to cross to voltage. JimN
John M
04-22-2008 13:43:18
One of 2 things come to my mind, you have the lights on dim, or you have 12 volt lights running off of 6 volt.
ron hall
04-22-2008 13:35:51
try replacing the ground cable to battery
PRTZMAN55
04-22-2008 12:49:00
THANKS
Ill look into that ,they are flat back lights,
may have to tear out the battery and chase the bees out to check.
harry
RustyFarmall
04-22-2008 13:12:53
 Re: LIGHTS in reply to PRTZMAN55, 04-22-2008 12:49:00
Be advised that they will probably never be as bright as what your car or truck is, but they should still be bright enough that you have difficulty looking at them.
PRTZMAN55
04-22-2008 12:00:08
okay,im not sure about the two settings the back of the switch matched up with the illustration in the it book and i belive it only had off on and another click for the rear lamp which i dont have fixed yet
RustyFarmall
04-22-2008 12:41:34
 Re: LIGHTS in reply to PRTZMAN55, 04-22-2008 12:00:08
I guess I'm not all that familiar with a 200, but somewhere, somehow, there has to be high beam/low beam selector. It may or may not be incorporated into the actual on/off switch.
RustyFarmall
04-22-2008 11:42:06
Your light switch should have both a dim and a bright position. Are you on the dim setting?
This is assuming that you installed the original style flatback sealed beam lights.
If by chance you installed a set of the teardrop shaped lights, you probably have a 6 volt taillight bulb instead of the 6 volt "1133" headlight bulb.
