Farmall 100 Need Help!
James Little
04-22-2008 16:09:35
Its getting gas and trying to fire some black smoke. My friend pulled the coil off and bought a new coil. Its a 6 volt system and the new coil is marked + and -. Which side hooks to the mag? Thank you very much for any help
1fortyfanatic
04-23-2008 06:48:35
 Re: Farmall 100 Need Help! in reply to gene bender, 04-22-2008 16:09:35
Also, with that black smoke, don't forget to duble check your plug wires for proper firing order. Good luck.
Dave
Glynn Moore
04-22-2008 17:48:03
 Re: Farmall 100 Need Help! in reply to James Little, 04-22-2008 16:09:35
If you have a 12 volt system, then you will need
a resistor on the 6 volt coil- Your hot wire from the switch to one side of the resistor-wire
from the other side of the resistor to the + on the coil---(-)from the coil to the distribitor Hope this helps Glynn
CNKS
04-22-2008 17:46:29
Wire from + terminal to the distributer if battery is + ground.
James Little
04-23-2008 05:07:04
 Re: Farmall 100 Need Help! in reply to CNKS, 04-22-2008 17:46:29
Thank you very much for the help! I will try it this weekend.
gene bender
04-22-2008 16:37:08
You said mag dont you mean a dist an the 100 should have a dist.
