International Red Paint
Bill Engledow
04-22-2008 17:55:27
CAN ANYBODY TELL ME THE NAME OF IH RED PAINT THAT WHEN APPLIED AND AFTER IT DRIES IT STAYS WET LOOKING. I BELIEVE DUPONT MAKES IT. ALSO DO YOU KNOW WHERE IT COULD BE BOUGHT? THANKS,
BILL
Mark from WI
04-24-2008 20:38:50
 Re: International Red Paint in reply to Bill Engledow, 04-22-2008 17:55:27
I do the same thing that DCW does works just fine for me. A base coat/clear coat finish can get expensive!
Bill Engledow
04-25-2008 15:40:42
 Re: International Red Paint in reply to Mark from WI, 04-24-2008 20:38:50
Thanks for info.
CNKS
04-22-2008 18:07:26
Acrylic enamel or acrylic urethane, for best results use two stage or base coat/clear coat like on the current cars. Source is PPG/DuPont/Sherwin Williams/Martin Senour/NAPA/Valspar or any major paint company. You won't find it at Case-IH or farm stores. $$$. IH red came in four shades --- . For good results use Case-IH 2150, it is shiny enough if you don't want to spend a lot of money.
Bill Engledow
04-22-2008 18:57:13
 Re: International Red Paint in reply to CNKS, 04-22-2008 18:07:26
THANK YOU,
BILL
DCW
04-22-2008 18:04:24
Here's what I used,in fact,I just painted my Super M.I bought my paint directly from Case IH,in this case Federal Yellow,but I get the red fromthe same source,then add Pro-Form Wet-Look hardener,part# PF599,from Carquest.
The paint at the dealer set me back $63 a gallon,and the hardener was $21 a pint.I got 2 gallons of paint,but really only needed one.
For me,the dealer is the cheapest source of paint,and its simple acrylic enamel,all you need.
I did the H I had with it,it never looked that good from the factory.
Bill Engledow
04-22-2008 18:59:08
 Re: International Red Paint in reply to DCW, 04-22-2008 18:04:24
THANK YOU,
BILL
CNKS
04-22-2008 18:13:45
2150 is "acrylic modified" ALKYD enamel, an improved version of the original alkyd enamel which appeared in the 30's. It has some acrylic properties including UV inhibitors to slow fading. Not quite as good as acrylic enamel, but usually good enough. Haven't checked the price in a long time and have never used it, I thought it was less than $50. The price is approaching that of true acrylic enamel, apparantly.
CNKS
04-22-2008 18:27:55
 Re: International Red Paint in reply to CNKS, 04-22-2008 18:13:45
I forgot you said federal yellow -- I imagine that is the same formulation as 2150, but may not be. If it was made by Valspar, they make about every formulation of paint.
