What charging system on 140??
1badcumminsdiesel
04-22-2008 18:40:21
I have a 1974 Farmall 140 and was wondering if it came with a 6 or 12 volt system. It has a generator but the battery looks to be a 12 volt. The negative on the battery is grounded to the frame.
1badcumminsdiesel
04-22-2008 19:25:18
 Re: What charging system on 140?? in reply to 1badcumminsdiesel, 04-22-2008 18:40:21
The ser # is 54170J. Thanks a million.
1badcumminsdiesel
04-22-2008 20:05:23
 Re: What charging system on 140?? in reply to 1badcumminsdiesel, 04-22-2008 19:25:18
Thanks Hugh I really appreciate the info.
Hugh MacKay
04-22-2008 20:03:06
140s with alternator are serial number 57724 and above. Yours falls between 45001 and 57723, 12 volt generator, negative ground, key start, with 4 way flashers.
Hugh MacKay
04-22-2008 19:19:32
It definitely would have been 12 volt. 140 electrical changed 4 times during production. It went from 6 volt generator, two different systems with 12 volt generator and finally 12 volt alternator. I have the wiring diagrams for all 4 systems and the serial number split when the changes occured.
If you wish give me the serial number and I can tell you exactly what you have. You are very close to models with alternator, in fact I think it happened prior to 74. I only have the figures on serial number, and have never translated those into years.
