M falters as throttle opens
m-mcoloma
04-23-2008 05:04:44
I have a 49 "M" that runs well both at idle and full throttle. The problem is it falters and sometime dies as you increase throttle. Going from idle to full throttle is a slow and painful operation. Any ideas?
Thanks
El Toro
04-23-2008 05:16:07
 Re: M falters as throttle opens in reply to m-mcoloma, 04-23-2008 05:04:44
I would open that main jet by turning that screw CCW at the bottom of the carb. to see if fixes the problem. Hal
jjamna
04-23-2008 05:12:22
Check the carb or the timing
