Surging 140
1badcumminsdiesel
04-23-2008 17:43:12
When I let off the clutch fast on my 140 the motor surges. When i'm plowing it does the same thing. If I bring it down to an idle it stops surging. It only seems to do it under a load. It idles fine and most of the time doesn't do it when i'm driving it under no load. Any ideas??
tn terry t
04-23-2008 21:09:42
 Re: Surging 140 in reply to Tony Morris, 04-23-2008 17:43:12
[img]third party image[/img]
you might want to listen to hugh he's more learnered than i but ive had luck using the bump stop method ref#26,27,28 and 32. they are located on the bottom of ref#11
1badcumminsdiesel
04-23-2008 18:36:34
 Re: Surging 140 in reply to 1badcumminsdiesel, 04-23-2008 17:43:12
Terry where would that adjustment screw be (what housing). Thanks
Hugh MacKay
04-23-2008 18:25:53
The problem is in the adjustment between governor and carburator. Try the adjustment right behind the generator or alternator. I always have to play with it, however there are guy on here that can give you an exact setting with engine stopped.
tn terry t
04-23-2008 18:22:10
 Re: Surging 140 in reply to countrystyle, 04-23-2008 17:43:12
there is a gov adjustment on the bottom of the housing its supposed to be under an acorn nut take that nut off and theres an adjustment try turning that screw in a little and retry the engine and see if that dont stop it surging
1badcumminsdiesel
04-23-2008 17:55:58
I forgot to mention that I just put a Carb. kit in and it was doing the same thing before the kit was installed.
Andrew Z
04-23-2008 18:23:23
 Re: Surging 140 in reply to 1badcumminsdiesel, 04-23-2008 17:55:58
get the manual and adjust the carb to the govoner. the I&T will show how to adjuest it. Sounds like an easy fix there.
Andrew
