Farmall 504 Transmission oil check plug
Ken Hines
04-23-2008 21:40:18
Can anyone tell me where to check the fluid level for the transmission on a 504?
Any help would be appreciated.
Ken
charles todd
04-25-2008 11:25:27
 Re: Farmall 504 Transmission oil check plug in reply to JVS, 04-23-2008 21:40:18
Fill level plug on left side of xmission, bout inline with the shifter, by the clutch, under the floorboard. Thanks Hugh, I did not know it was there.
Ken Hines
04-24-2008 20:10:45
 Re: Farmall 504 Transmission oil check plug in reply to Ken Hines, 04-23-2008 21:40:18
Thanks for the info. This one has the power steering.
TractormanNC
04-24-2008 04:57:30
If it does not have power steering, there is a 1/2 in. pipe plug on the left side of the transmission below the clutch pedal and forward of the LH brake. If it has power steering, the P/S and oil cooler return to an elbow which screws into the same opening. This is a special elbow which also has a 1/8 in. pipe plug in it for checking the hyd oil level. Hope this helps.
charles todd
04-24-2008 03:00:27
 Re: Farmall 504 Transmission oil check plug in reply to Jerry Jordan, 04-23-2008 21:40:18
Hugh MacKay said: (quoted from post at 04:42:04 04/24/08) Ken: Most Farmalls of that era have the plug forward of brakes, on clutch pedal side, about 1/3 distance from bottom on transmission case. It should be a 1/2" plug, maybe a bit larger.
Most of my experience has been 300 and 560. I had a 504 and 656, came with a farm I bought. I know the 656 had a dipstick, think the 504 did as well, but I didn't keep it so I'm not certain. That 504 and 656 were 1967 models, and that would be last year of 504. I know most early 504 used the fill to level plug.
I'll have to check my manual but I am certian that there is no dipstick, at least my 1962 F504D does not. I did not know of a level plug either. I have been told to fill until the oil reaches the top of the IPTO clutches (in the fill hole).
Hugh MacKay
04-24-2008 09:07:38
 Re: Farmall 504 Transmission oil check plug in reply to charles todd, 04-24-2008 03:00:27
Charles: You read what I said. I did not say all 504s had a dipstick. I'm not even sure the last ones did, but the may have.
If your checking the oil in you transmission as you suggest, it may go dry. You best get a manual
Hugh MacKay
04-24-2008 02:42:04
petetx
04-24-2008 04:59:54
 Re: Farmall 504 Transmission oil check plug in reply to Hugh MacKay, 04-24-2008 02:42:04
Hugh is right my 504 has a plug inline with the fill plug on the side of transmision housing
