Re: Farmall wiring diagrams - new link
Janicholson
04-24-2008 06:10:35
I'll add to Bobs good solutions one that keeps it looking stock at the controls point of view.
From NAPA, buy a oil pressure switch with two terminals that is closed with pressure above 5PSI.
Wire this from starter switch battery terminal, to the oil sw, then from the other term to the #1 on alt. Thus when running it automatically gets exciting voltage, and when stopped, that sw stops the exciting volts. JimN
FarmallDude
04-24-2008 21:22:05
 Re: Farmall wiring diagrams - new link in reply to Janicholson, 04-24-2008 06:10:35
Jim N: Thank you very much, for the good info on the oil pressure switch. I WILL go to NAPA or Carquest and get me one. Both auto parts, are Real close.
Thanx, again Jim N
BTW, you're not related to Jack, are you!? ;-)
Bob M
04-24-2008 07:04:15
Jim/FarmallDude - That's a good one too and I've got a diagram for it...
