converting from 6volt to 12 volt on farmall H
Jeff Proxmire
04-24-2008 13:58:12
Would like to know how to convert my 6 volt to 12 volt wiring diagram and parts I will need.
tn terry t
04-24-2008 20:43:07
 Re: converting from 6volt to 12 volt on farmall H in reply to randy hall, 04-24-2008 13:58:12
Jossette said: (quoted from post at 22:57:11 04/24/08) hg
third party image
only thing i could add, it keeps coming up that"my tractor wont shut off " you must USE that WARNING LITE some folks use a diode, in the diaghram
Jeff Proxmire
04-27-2008 07:40:22
 Re: converting from 6volt to 12 volt on farmall H in reply to tn terry t, 04-24-2008 20:43:07
Will this diagram work with a magneto. And will I need to make a bracket for the alternator or could I have the generator rewired for 12 volt positive ground.
Jossette
04-24-2008 19:57:11
 Re: converting from 6volt to 12 volt on farmall H in reply to Jeff Proxmire, 04-24-2008 13:58:12
third party image
hg
Jeff Proxmire
04-27-2008 07:58:56
 Re: converting from 6volt to 12 volt on farmall H in reply to Jossette, 04-24-2008 19:57:11
Will this diagram work with a magnateo. And will I need to make a bracket for the alternator or could I have the generator rewired for 12 volt positive ground
arod
04-24-2008 14:03:21
Search this forum for Bob Melville's wiring diagram.
Trust me, this question is asked on a daily basis.
Have fun rewiring ! I put alternators on all my farmalls too. Makes for brighter, whiter lights.
Jeff Proxmire
04-27-2008 08:09:48
 Re: converting from 6volt to 12 volt on farmall H in reply to arod, 04-24-2008 14:03:21
Thank You for showing were to go on Bob Melville's wiring diagrams.Will the stock wiring diagram work with a alternator I'm running a magnateo and also if go with a alternator what one should I us and will I need to make a bracket don't want to cut the hood up also what belt some I us.
