300 propane over haul
pompre
04-24-2008 15:01:48
Ok...I am looking to overhaul my 300lp tractor, are the engine and valve kits that are advertised on this site work for lp as well as gas or is there some changes in between the two engines. Havent went down to my friendly implement dealers yet to see(30 miles away) I would think they are the same but thought I would ask you folks. Thank you
Edpap
04-24-2008 18:04:35
 Re: 300 propane over haul in reply to pompre, 04-24-2008 15:01:48
Hello,
Yes there is a difference between gas and lpg valves, but you need to look at the casting # on your head if it is a true LP head the casting # should be 364017R1. Good Luck Ed
CNKS
04-24-2008 17:39:08
The 300 had a higher compression head, someone else can answer the valve question. If you don't have a parts book, check the part numbers on www.caseih.com.
