560 wont stay running unless Solenoid is jumped
ITFormulaGuy
04-25-2008 07:58:01
The tractor will start and fire for a second and then shut off it will not keep running unless the starter solenoid is jumped with a small wire from one of the small terminals to the batter bost on the solenoid. thinking it was the solenoid i replaced it and still having the same issue. any ideas where to look next?
El Toro
04-25-2008 16:23:46
 Re: 560 wont stay running unless Solenoid is jumped in reply to ITFormulaGuy, 04-25-2008 07:58:01
Its the ballast resistor that's causing that problem. Hal
garytomaszewski
04-25-2008 11:24:47
Should be two wires on the coil, one to where you are jumping on the solenoid,this gives you 12 volts to coil to help starting. The other is the run circuit from the "I" terminal of the ignition switch, it is either resistance wire or goes through a ceramic resistor to give you 6.6 volts so you don't melt coil/burn points. Start doing conntinuity checks and find out where the open is in the run circuit.
the tractor vet
04-25-2008 08:54:27
Check the ballist resistor up by the coil maybe a bad wire or wired wrong . There are two wires to the coil one will give a full 12 volts when ya hitthe starter button for a full shot of 12 volts to the coil for a fast start then once y let off the starter button then the ballist resistor takes over and you should have somewhere between 6-8 volts at the coil . So it is either a wire problem or a resistor problem .
ITFormulaGuy
04-25-2008 08:40:36
with the key on the on/start position i cross the terminals on the solenoide then jump back up on the tractor hit the switch and it starts runs fine. i have to turn the key off so power is cut then go back down to the solenoide and once i undo the clips the tractor will finally shut off.
ihc49
04-25-2008 08:11:06
wiring problem, ign. switch?
Allan In NE
04-25-2008 08:09:59
Back track from the coil primary. You have no ignition feed. Wiring, resistor or ignition switch.
It is running on the "start" circuit only.
Allan
Janicholson
04-25-2008 08:20:13
 Re: 560 wont stay running unless Solenoid is jumped in reply to Allan In NE, 04-25-2008 08:09:59
Allan is correct. there is surely voltage from the bat term of the starter relay (solenoid) to the ignition sw, or it would not crank. Thus the wire to the resistor, or the resistor, is probably at fault. The ingition switch could also have a faulty contact at the run position. JimN
ITFormulaGuy
04-25-2008 08:42:13
 Re: 560 wont stay running unless Solenoid is jumped in reply to Janicholson, 04-25-2008 08:20:13
when you say resistor, are you talking about the porclin style resistor? I'm and H and M guy the 560 was a big jump..lol
Janicholson
04-25-2008 09:14:04
 Re: 560 wont stay running unless Solenoid is jumped in reply to ITFormulaGuy, 04-25-2008 08:42:13
yes, there are various styles, including resistor wire that looks like regular wire in the system. JimN
