#100 manure spreader
Cue P.
04-25-2008 09:57:35
third party image
I have what i think is mccormick 100 manure spreader. Looking to put new tires on it and have noticed in pictures of spreaders on this site and other sources that the narrow point of the bar tread is usually mounted in reverse on the wheel. ie the narrow point of the bars points to the rear as opposed to a tractor tire where the narrow point of the tread points forward. Is there a reason for this? Also if anyone can provide decal placement info i'd appreciate it greatly! Thanks!
Steven f/AZ
04-25-2008 18:49:44
 Re: #100 manure spreader in reply to Cue P., 04-25-2008 09:57:35
I put car tires on mine and have never had a problem.
Lucien cyr
04-25-2008 10:13:11
third party image
For traction
Merle Hoppenworth
04-25-2008 10:04:43
Your spreader is ground driven so the tires should be reversed direction from a tractor. The ground is pushing the wheel to turn where a tractor is turning to push the ground.
