Dumb A brake question
chuck davis
04-26-2008 05:29:20
I am getting ready to put my A back together and dont know if i have the drum in the right position.
I should have punched a mark on the shaft when i took it apart i guess.
It seems to be on as far as it will go as i tap on it it wants to start driving the outer bearing out of the casting. I just dont want to do this twice or three times if i dont have to. Thanks C.D.
Dave BN
04-26-2008 16:35:46
 Re: Dumb A brake question in reply to chuck davis, 04-26-2008 05:29:20
Their should be a set screw(with lock nut) that holds that drum in place. You should be able to see where that set screw was biting into the shaft. Just put it back in that same place. Dave.
