Order Farmall Cub Parts Online
Problem with newly overhauled Cub Engine
Gale Roberts
04-26-2008 22:58:22
I just overhauled my 1948 Cub, Valves and seats resurfaced new valve springs, with Valve clearances set at .013, all new Crank and Rod bearings, new Piston Rings,,new champion D18y Spark plugs set at .025.I got it running but it has no power and sounds like it is late on time but I checked the Magneto all over installed new Points, Condensor, coil, rotor,Cap, and new Spark plugs. It has good spark and I timed it according to the manual. The two center cylinders seem to run colder the end ones like it is not firing as good on the middle cylinders. The center spark plugs feel much cooler to the touch after running. I installed a new kit in Carburetor and set float to the manual specs and have plenty of gas to carburetor. Can anyone tell me what might be my problem. Thanks....Gale
1fortyfanatic
04-27-2008 15:47:44
 Re: Problem with newly overhauled Cub Engine in reply to Janicholson, 04-26-2008 22:58:22
Gale, don't feel like a fool. I was going to suggest the plug wires order as well; and why do you think we all wanted to have you check it? Because we've all done the same thing! Now, you too will be a "genius" when someone has a similar question :P !
Dave
Edpap
04-27-2008 07:29:49
 Re: Problem with newly overhauled Cub Engine in reply to Gale Roberts, 04-26-2008 22:58:22
Hello Gale,
I would do a compression test to eliminate a valve problem. then I would check your manifold if you are sucking air on the center cyl's it could do this. are the plugs wet on 2 and 3 ? maybe bad wires.
Good Luck Ed
Bigdog
04-27-2008 07:14:51
Re-set your valve clearance to .015" cold.
billde
04-27-2008 05:12:09
Read Hal's firing order as if you are looking at the cap. No 1 at roughly 2 o'clock.
El Toro
04-27-2008 03:52:25
Make sure your plug wires are in the correct firing order on the mag's cap. Hal
2-1
4-3
PS: You should bring No1 piston to TDC on the compression stroke and then see where the rotor is pointing. It should be at the No1 plug tower on the cap. Did you remove the cam & crankshaft?
Gale Roberts
04-27-2008 07:01:58
 Re: Problem with newly overhauled Cub Engine in reply to El Toro, 04-27-2008 03:52:25
I did not remove Camshaft or crankshaft I did an in frame overhaul did not remove cover from front of engine. I have the Spark plug wires in the proper places from the magneto cap to the spark plugs. I am sure it is not due to improper firing order. I am stumped on this. Any other ideas on this are welcome and thanks for any of your help fellows..... Gale
Gale Roberts
04-27-2008 12:42:41
 Re: Problem with newly overhauled Cub Engine in reply to Gale Roberts, 04-27-2008 07:01:58
I now feel like a fool as I went out this morning and rechecked the wires from Magneto cap to the Spark Plugs and the two center cylinder wires were reversed. I changed them and now it runs ok, I was sure that I had them right in the first place but I was wrong. Thank you all for your help and you was right the firing order was screwed up..... .Gale
El Toro
04-27-2008 12:42:11
Do those plug wires have copper wire? You need them with a mag. Hal
Bob
04-26-2008 23:05:25
Sounds like the firing order is messed up.
