826 engine swap
The nw farm
04-27-2008 04:16:07
Besides that the front mounting on a D-414 is to wide and must be cut is there any other problems I will meet when I will change my D358 to a D-414. The fuel linkage and cooling will be on the same side as the D-358.
Thanks
MN Scott
04-27-2008 11:04:23
 Re: 826 engine swap in reply to The nw farm, 04-27-2008 04:16:07
The 414 is about four inches longer than the 358. You will need the frame rails from a 966 or 1066. The power steering lines will need to be lenthened. You will need the rear engine mounting plate, engine to transmission. You will have to add four inches to your hood. You will need the flywheel from a 414. There's a few other small things you will need to but they can be fabricated. Big job good luck.
