i.d. farmall h eng.
richard a
04-27-2008 04:48:22
i brought a shop manual which has several different motors listed wondering what motor my 1941 h is? thanks
Owen Aaland
04-28-2008 02:11:05
 Re: i.d. farmall h eng. in reply to richard a, 04-27-2008 04:48:22
The 152 and 153 both have the same bore and stroke so they are the same size. The two different numbers are to tell them apart.
Janicholson
04-27-2008 05:46:48
153 CID is the normal size It can be upped with a thin sleeve kit to 164 CID. This is the same as a Super H. In the years since it was made there is no way to know without measuring, unless you know the original owner. JimN
RustyFarmall
04-27-2008 08:42:12
 Re: i.d. farmall h eng. in reply to Janicholson, 04-27-2008 05:46:48
Actually, the Farmall H engine is 152 cubic inches. The 153 is a different engine, I believe the 153 was installed in the 504s?
Janicholson
04-27-2008 16:19:45
 Re: i.d. farmall h eng. in reply to RustyFarmall, 04-27-2008 08:42:12
You are correct, my finger got confused on the number. JimN
richard a
04-28-2008 14:06:03
 Re: i.d. farmall h eng. in reply to Janicholson, 04-27-2008 16:19:45
guess i have 152 cid. thanks to all when i find out why the motor wont turn i will post
