Whats this M worth?
tedsxb
04-27-2008 16:49:28
I was at my buddys house and out back he had a farmall M. It was pretty straight and had just some surface rust, stil showed original paint in some areas. I asked him about it and apparently antifreeze got in the oil and it was determined that the block was solid just the headgasket was bad and one piston sleeve was cracked. He didnt know what price to ask, so I wanted to know what a tractor like this is worth. I dont know what accessories it has, but it has hydraulics. I could do the work on the motor, but I wanted to know a reasonable price to offer. Thanks
the tractor vet
04-27-2008 18:40:44
 Re: Whats this M worth? in reply to tedsxb, 04-27-2008 16:49:28
IF one sleeve is cracked then GUESS what the block is ALSO cracked behind the sleeve .
linemanfarmer
04-27-2008 17:57:42
Depending on the shape of the tires, back ones mostly, but here where I live there are Ms everytime you turn around sitting in fence rows. If the tires hold air and would last a while for working it, Id say $500-$700 at the most. Derek
