Hydraulic pump drive on transmission - M
Charlie Hays
04-27-2008 20:45:13
I am trying to remove the hydraulic pump drive on the front of the M transmission so I can replace the seal. Does the drive have right hands threads? I made a tool to fit my impact wrench, but haven't loosened the drive.
Thanks in advance for the information.
Charlie
Wayne in MN
04-28-2008 06:33:41
 Re: Hydraulic pump drive on transmission - M in reply to Charlie Hays, 04-27-2008 20:45:13
Lock the brakes, put the transmission in reverse, & turn the coupler lefty-loosey.
Once it breaks loose you should be able to remove with your fingers.(it self tightens when in use)
Dave S.
04-28-2008 04:42:55
The transmission and the pump drives are both right handed thread
Mike L
04-28-2008 04:06:43
My 52 M Farmal has right hand threads.
Charlie Hays
04-28-2008 05:32:48
 Re: Hydraulic pump drive on transmission - M in reply to Mike L, 04-28-2008 04:06:43
Thank you both for the information.
Charlie
