Goo on A Oil Breather
nyvines
04-29-2008 06:02:38
I seem to have a white gelatenous goo on the breather of my A... I assume this is moisture of some type that has built up in the crankcase. I am hoping that it is not condensed antifreeze. If it is is it advisable to try some stop leak to try to seal where ever it may be coming from? I realize that is a temporary measure till I can get it apart in the winter for a proper rebuild. I wonder if its OK to do with the Thermosyphon type of system. Need advice from the experts.
teddy52food
04-29-2008 10:15:51
 Re: Goo on A Oil Breather in reply to nyvines, 04-29-2008 06:02:38
Some years ago, I started plowing in the spring with the H that had been used off and on during the winter ,short trips that didn't get it warmed up good. It started blowing smoke from the breather like never before. After a few more rounds, it quit & was back to normal. The oil got hot enough to boil the moisture off & make smoke out of the breather.
Allan In NE
04-29-2008 06:55:32
That "goo" is caused by two things: Lack of service and lack of hard work.
Change the oil/filter and work the snot out of the thing. That "goo" will disappear.
Allan
ScottyHOMEy
04-29-2008 06:47:32
The white goo is most likely from water condensed on oil. But I wouldn't yet jump to any conclusions about where it came from.
I'd do two things first. One is sozzle that breather cap (I'm assuming you're talking about the cap on the valve cover, where you pour the oil in) in kerosene or diesel to clean off the accumulation you have, and watch it going forward. Let it drain and air dry before you put it back on.
More importantly,I'd also drain the oil from the crankcase to see if there's any water in it. Do it with the engine having been still for a couple of days, and hold a clear jar under the drain to catch the first quart or so that comes out to see what's on the bottom. You mention antifreeze. If you get some antifreeze in the bottom of the jar, then you may have a leak in the head gasket or around the o-rings on the sleeves or a crack somewhere.
If there's antifreeze in the cooling system and you get some amount of clear water (i.e., no antifreeze) out of the crankcase, I'd say your only problem is likely condensation, which would be consistent with water condensing like dew in the breather cap.
This could be coming just from the spring weather with its dew points, or it could be from keeping the tractor inddors in in a space that's only occasionally heated. I know I cringe evry time I turn the heat on in my garage and see the condensation form on the outside of my recently re-done BN, 'cause I know the same sweat is forming on the inside of the motor. That's the reason that oil changes are ecommended not just for miles or hours run, but also for periods of time.
ScottyHOMEy
04-29-2008 07:21:11
 Re: Goo on A Oil Breather in reply to ScottyHOMEy, 04-29-2008 06:47:32
And just to second what the others are saying, it can be from long-term lack of maintenance, in which case a little condensation every year adds up to a lot of accumulated condensation. If you've got goo on the breather and it is coming from condensation, you can bet that the oil in the crankcase is turning into that same kind of goo. NOT a good thing.
Clean the breather cap. Change the oil (looking for signs of anti-freeze or water). Then do both regularly.
If you don't get any antifreeze, or if you get less than a cup or so of water out of the crankcase, I'm gonna say regular maintenance is gonna solve your problem.
RustyFarmall
04-29-2008 06:12:12
Basically what you are seeing is the result of condensation in the crankcase. I doubt if you have any leaks, although it is possible. Forget the stop leak. What you need to do is change the oil and filter, clean that breather, and then make that tractor work hard so it gets good and warmed up. That yellowish/white goop should disappear, or at least diminish.
