Farmall M flywheel
Ave
04-29-2008 06:06:49
The flywheel turns, the crank does not. How bad is it?
Janicholson
04-29-2008 14:46:59
 Re: Farmall M flywheel in reply to Ave, 04-29-2008 06:06:49
The flywheel will not come out the bottom, but all the clutch parts will. If these are out, the attachment of the FW can be checked. If it is still connected, the crank is broken. Pulling the pan willtell the story. Then splitting is in order. JimN
Janicholson
04-29-2008 14:46:52
Allan In NE
04-29-2008 06:24:45
Is it actually the flywheel turning or just the ring gear?
Have seen those gears just spin on the flywheel.
Allan
Ave
04-29-2008 06:30:33
 Re: Farmall M flywheel in reply to Allan In NE, 04-29-2008 06:24:45
Thanks, gents - I guess. I had hoped it was the ring gear, but I turned the flywheel. The shop manual I have indicates different procedures for different series tractors. How do I tell? This is a 1940 model. Looks like I'm going to learn how to split one - not looking forward to it.
ScottyHOMEy
04-29-2008 07:23:38
 Re: Farmall M flywheel in reply to Ave, 04-29-2008 06:30:33
Ouch!
You're in for some work.
Hoss in Me
04-29-2008 06:14:01
Ya gots a broken crank. Hoss
JT
04-29-2008 06:07:50
unless all 4 bolts are out of the flywheel, you got serious problems.
Jim
