H carb adjustment
forgetful
04-29-2008 06:17:20
H was running rich. I ajusted the carb screws. Forgot what does what. Need a refresher coarse starting with the screw at the governor tube.
Thanks in advance
Rollo
Mike CA
04-29-2008 13:25:43
 Re: H carb adjustment in reply to forgetful, 04-29-2008 06:17:20
RyaninKS said: are these the same for an m?
RustyFarmall (the carb guru who taught me what little I know) says yes.
RyaninKS
04-29-2008 11:23:30
Mike CA
04-29-2008 07:57:06
forgetful said: ...starting with the screw at the governor tube.
At the governor tube, that is the Idle Speed Adjustment. Factory setting for that is 1 and 1/2 turn out from seated.
Below that is the Idle Mixture (rich/lean) adjustment. I believe factory adjustment was 2 turns out from seated (I don't have my book in front of me)
At the bottom is the High Speed Adjustment screw. Initial factory settings were 3 turns out from seated.
Hope that helps.
CNKS
04-29-2008 17:42:28
 Re: H carb adjustment in reply to Mike CA, 04-29-2008 07:57:06
The 3 turns out is not necessarily the factory setting, that is just to allow it to start. Once ruuning and warmed up, open the throttle all the way, then turn the screw in until the engine begins to stumble, then out until smooth plus maybe 1/4-1/2 turn more. Leaner is better. Adjust the idle mixture screw also. Both may need to be done more than once. On the other hand, the main screw on the Super H and M, is set at the factory 5 turns out. Different carb.
