DID MW MAKE Flywheel Ring Gears???
MAGMAN
04-30-2008 09:37:53
I have a real weird looking H flywheel ring gear here.Its almost like the teeth have been drilled between the teeth on it. It is factory though. JON
Janicholson
04-30-2008 15:30:42
 Re: DID MW MAKE Flywheel Ring Gears??? in reply to MAGMAN, 04-30-2008 09:37:53
I do not know what M&W made, but it could have been loose enough on the rim of the wheel that a PO may have pinned it in place to prevent rotation! That would make it a bit difficult to remove if the pins are hard. JimN
