The last of the M hitch templates went out today
dansuper27
04-30-2008 10:09:03
Hi all....the last 6 requests for the fasthitch mounting plate template went in the mail today. If your inclined drop $4.00 in an envelope back to my return address on the tube to cover materials. Keep us all up to date with pictures of any progress to your prospective M's or H's. As I've posted before that hitch makes the M tractor a whole other breed of animal. The only hydraulics I use is the belly pump with one control valve for the hitch and another for the remote. Mine are mounted to the right of the seat. I'm sure the live hydraulic pump on the distro drive would be even better and I plan on that for a future upgrade but the belly pump works fine for now.
Randall L. Daggett
05-01-2008 05:50:38
 Re: The last of the M hitch templates went out today in reply to dansuper27, 04-30-2008 10:09:03
Thank you sir...we'll get something in the mail soon. Did you use a metal cutting bandsaw to cut that thickness of metal??
dansuper27
05-01-2008 18:15:31
 Re: The last of the M hitch templates went out today in reply to Randall L. Daggett, 05-01-2008 05:50:38
I used a plasma cutting torch and then a grinder to smooth it to size. Lots of work but worth the result. You should be able to use a standard cutting torch and cut over size a little then grind for final finish.
kossuth
05-01-2008 05:25:03
Thanks a bunch Dan, and $5 is headed your way. I really appreciate it.
Lee in Iowa
04-30-2008 19:52:20
I got mine the other day. Thank you very much. I'll get some money in the mail. Lee
Armand Tatro
04-30-2008 17:57:32
If I may ask, how many templates did you send out? Armand
dansuper27
04-30-2008 20:14:53
 Re: The last of the M hitch templates went out today in reply to Armand Tatro, 04-30-2008 17:57:32
There were 17 requests for templates.
