Super A Seal
Tim Plude
04-30-2008 13:46:08
My uncle is restoring a Farmall Super A. He has it split, and needs to get the seal the is under the steering column. Does anyone know where he could get one in the mid-michigan area, or even order from out of state?
tractorsam
04-30-2008 14:48:24
 Re: Super A Seal in reply to Tim Plude, 04-30-2008 13:46:08
I'm going to take a wild guess that you're talking about the transmission input shaft seal and as Greg suggested - try your local CaseIH dealer. tractorsam
Janicholson
04-30-2008 14:27:59
Unless someone knows a bunch about your meaning, and can answer you, we need more info.
Steering on an A runs down th rt side and has several connections/joints. Then at the front casting, it enters the gears. The underside then has an arm comming out, going to the linkage.
Go to caseih.com and go to the search for parts area.
then pick begin your search for parts here.
Then type in an A in the model box at the top.
Then find steering.
There are complete diagrams of all parts. Look up the IH part number. A dealer might have them, or a seller like Motion Industries, Chicago Rawhide, or National. JimN
Greg-N-CA
04-30-2008 14:19:49
Actually, you can get it from your local CaseIHC Dealer.
