140 distributor rebuild
Tracy H
04-30-2008 17:20:25
Trying to rebuild a distributor for a 140.It is the original distributor.What is the best way to get the brass bushing and seal out of the distributor housing? thanks for the help.
Tracy H
04-30-2008 18:06:20
 Re: 140 distributor rebuild in reply to Tracy H, 04-30-2008 17:20:25
do you know where i might find the bottom seal and bushing other than the ih dealer.thanks again.
Janicholson
04-30-2008 18:29:09
 Re: 140 distributor rebuild in reply to Tracy H, 04-30-2008 18:06:20
Motion Industries, or any good bearing shop. they can also be made easily from oilite bronze stock. If the shaft is worn, replace it, or use a bushing long enough to be on a unworn spot. JimN
Janicholson
04-30-2008 17:35:33
Find a cheap 1/4" drive small socket close to the diameter of the bushing. Grind it flat on the end touching the bushing, and use an extension to push it out. A big vice is nice, or tapping with a brass hammer. JimN
