9X24 tires for a 100
Patrick Martin
05-01-2008 00:36:30
Hey guys, quick question.....9X24 or 9.5X24 is the correct rear tire size for a Farmall 100 right?
Patrick Martin
05-01-2008 20:59:10
 Re: 9X24 tires for a 100 in reply to Patrick Martin, 05-01-2008 00:36:30
Woops, here is the link activated.
Link
Patrick Martin
05-01-2008 20:58:18
I'm not sure if what I have are the 11.2X24's or not so please take a look at this pic and see what you think?
Link
I kinda wanted to go with a smaller size to get a little more torque and slow the tractor down a little. Also thinking about something skinnier too.
Do any of you have a pic of the 9.5X24's on a similar tractor? I'd like to know what the end result will look like. :D
rich4
05-01-2008 15:22:27
9.5 would be the replacement for old 9.0 Any increase in non stock tire size (10.2 or 11.2 etc) would speed up ground speed of your tractor, Then how wide is your rim, depends on what you are doing, you could drop down a gear maybe. when we went up one tire size on a Farmall C we allmost went too far for the gear we were using previously for heavy work. Keep that in mind, check circumference of tires and realize that when buying. Larger width tires are not just wider, but a lot taller.
Marv
05-01-2008 10:55:41
Just put new tires on my SA. I have 10" rims so replaced with 11.2X24's. Check your rim size and don't go 1" over the rim width. The offsets came with several rim widths. Some as narrow as 8"'s up to a width of 11"'s. Marv
Glynn Moore
05-01-2008 07:21:52
Down here in south Ga. most everyone runs the
11-2-24-- This is the size I prefer on any of the
offset farmalls--The 9.5 is too small and the 12
series are too large--If you are doing any heavy
pulling such as harrows, etc-I run rear wheel weights and loaded tubes/tires--Does an excellent job this way---glynn
Jack OH
05-01-2008 08:51:31
 Re: 9X24 tires for a 100 in reply to Glynn Moore, 05-01-2008 07:21:52
So Glynn, do those 11-2x24 tires fit on the stock rims ok?
Jack
mkirsch
05-01-2008 04:56:45
Patrick, any 9-24 tire you find will probably be dry rotted by now, as that is the old sizing system used up into the 1950's.
9.5x24 is the equivalent size in the newer sizing system.
Jim in NC
05-01-2008 04:21:41
I have a farming buddy that has 11.2x24 on his 100 and they look and work great. They give the tractor more height for cultivating.
gene bender
05-01-2008 00:44:46
The new size would be 9.5. They will fit good on a 8in rim.
