Farmall M Steering
Howard Schmader
05-01-2008 10:46:27
The steering on my Farmall M is very loose. Any ideas on tighting it up. The front wheels wobble real bad in fifth gear.
r4etired
05-01-2008 18:16:04
 Re: Farmall M Steering in reply to Howard Schmader, 05-01-2008 10:46:27
Remove the cover thats on top of the pedistal and check if the worm is running in the center of the gear. Normally as the thrust bearing wears the worm will ride above center, this causes it to be loose.Make a spacer washer the thickness the same as the worm is above center and place it on top of the thrust bearing, Lots of bearings have been replaced that adding a shim would have saved for a long time. The 400-450's were bad for this,I have shimed them as much as 1/8in.There are several other contributing factors causing loose steering but most are noticeable. Good Luck
GordoSD
05-01-2008 16:10:23
Just start at the steering wheel and work your way down to the wheel bearings. Replace anything that is loose or worn. There is no quick easy miracle fix.
Gordo
neblinc
05-01-2008 11:43:47
Howard Schmader said: (reply to post at 13:46:27 05/01/08 )
Here is an older post to give you some ideas.
Link
Randy
