SA gasket OH set- simple question
P and R Pete
05-01-2008 18:11:02
The overhaul-gasket set I got for my Super-A included these two items.
third party image
The rubber seal is obvious- it's for the touch-control hydraulic pump, though it's odd it was included, because everything else I needed to overhaul the pump I had to get as a different gasket set, and I also needed to get a separate gasket set for the hydraulic block. This rubber seal was the sole thing included for the hydraulic system in the OH set. Go figure.
Turned out my pump uses a rubber O-ring anyway, so the seal is extra.
My question is what does the felt gasket fit? I saw no obvious place during the engine overhaul, nor have I seen a picture of a hydraulic pump that uses a felt seal.
Just wondering.
ih560
05-01-2008 18:52:08
 Re: SA gasket OH set- simple question in reply to P and R Pete, 05-01-2008 18:11:02
It's looking good, you will have to post some more pictures as you go. Best of luck with everything.
P and R Pete
05-01-2008 18:36:56
Ah!
Thanks Dustin.
Fer crying out loud, I never thought of the governor, which is still sitting on a shelf waiting it's turn for reinstall.
I had the governor overhauled last spring by a IH dealer, another reason I dumbed-out, because I gave it no thought to needing anything.
So it's me, not the gasket-packer! LOL
ANyway, I finished the hydraulic block and got that bolted down today.
Governor goes back on tomorrow.
third party image
ih560
05-01-2008 18:19:23
And by the press in seal, I mean the rubber one in your picture. Both those in the picture are governor seals, there are no hydraulic seals in an engine overhaul Gasket Set. I sell these kits myself and have installed many of them as well.
Hope this helps
Dustin Moran
Farm Parts And More
(859) 433-5798
ih560
05-01-2008 18:15:23
P and R Pete said: (quoted from post at 18:11:02 05/01/08) The overhaul-gasket set I got for my Super-A included these two items.
third party image
Just wondering.
They are governor seals. The felt one goes on the lower shaft that runs to your carb shaft and the press in seal goes on the top shaft that comes from you throttle lever. If you need any more help just let me know.
Dustin Moran
Farm Parts And More
(859) 433-5798
