Kiwana Disc
WV Ike
05-01-2008 23:08:15
I have a Kiwana Disc and can't seem to find any parts for the old girl. Does anyone know where to find parts for her. Thanks for any help.
Gene b
05-02-2008 16:43:54
 Re: Kiwana Disc Va Gasman in reply to WV Ike, 05-01-2008 23:08:15
blades should be found most places. call 314-314-9948 i will try to help.
glennster
05-02-2008 10:13:13
 Re: Kiwana Disc in reply to WV Ike, 05-01-2008 23:08:15
shoups in kankakee il has parts for the kewaunee disk. blades, spools, axles, bearings ect. look on line at shoupparts.com, if the parts you need arent listed on the on line catalog, give em a call and they can fix you right up.
Curt W.
05-02-2008 05:53:04
Kewanee was bought out by Bush Hog. They still carry parts.
Curt W.
05-02-2008 06:06:14
 Re: Kiwana Disc in reply to Curt W., 05-02-2008 05:53:04
I forgot to mention. I've found that alot of IH parts work on mine. It depends on what your looking for or what model you have.
IaGary
05-02-2008 05:32:50
This may help
MN Dave 2
05-02-2008 05:22:44
We used to have one, and the gang bearing was a hex shaft inside. We paid $40 for them at a Kewwannee dealer until I discovered that a IH corn head used the same bearing for $7.
VA Gasman
05-02-2008 03:35:21
I know your pain. I have a old single bottom JD trailer plow on spoke rims and i can't find any plow shears, points or landslides. I also have a dearborn disc harrow. I checked 4 different suppliers online but no jackpot. I can resurface plow parts but not disc blades.
