Hydraulics question
lwilli
05-02-2008 05:20:23
Got an International 404 that when first started, lift raises up but when lowered will not come up again. Can shut off tractor and let it set awhile and when started, lift will come up. Any suggestions what could cause this?
bc
05-02-2008 16:23:34
 Re: Hydraulics question in reply to lwilli, 05-02-2008 05:20:23
Sounds like it is low on hy-tran. Does it leak anywhere? Don't take long for a leaky cylinder to go through a lot of fluid. Could be other possibilities but I'd start there but you haven't said when you last run it and how it worked then.
