400 cyclo planter
Derik in ND
05-02-2008 17:10:53
Hey just bought a cyclo 400 planter, and according to the chart, for the planting rate i want to use it says 7 mph! Do i really have to plant at such a high speed?
Derik in ND
05-08-2008 08:47:57
 Re: 400 cyclo planter in reply to Derik in ND, 05-02-2008 17:10:53
Does anybody know of any type of no-till setup available? Anybody have dry ferilizer for an 8 row? And does anybody know how to set the brushes? there's just a wire holding it down
Derik in ND
05-02-2008 19:18:08
Anybody know of any options for no-till with one of these?
Steven f/AZ
05-02-2008 20:36:16
 Re: 400 cyclo planter in reply to Derik in ND, 05-02-2008 19:18:08
Derik in ND said: (quoted from post at 19:18:08 05/02/08) Anybody know of any options for no-till with one of these?
My brother-in-law did min/no-till with his 800 cyclo... I don't believe the 400 is really conducive to being set up for no-till, but anything is possible with the right modifications.
James22
05-02-2008 19:11:01
The others have given the corrrect advice. Maximum speed is 7 mph, and you would be much better served if you don't go above 5 mph. Better yet, 4 to 4.5 mph.
Allan In NE
05-02-2008 17:59:44
Those darned Cyclos are a heck of a planter, but they have a few idiosyncrasies.
Keep the tires aired up, never put 'em in the ground sitting still, if it has that two-bit monitor, throw it away to maintain yer sanity, always keep the drive chains tight and plant as close to that chart as ya can (they plant better at speed).
I always planted in Hi second with the thing wound up to 11 ounces of air on a 766D and 16.9 X 38 tires.
Allan
Derik in ND
05-02-2008 18:03:05
 Re: 400 cyclo planter in reply to Allan In NE, 05-02-2008 17:59:44
Does anyone out there have a dry fertilizer set up off an 8-row that they'd be willing to part with?
Steven f/AZ
05-02-2008 17:47:46
The 400 cyclo air planter will work best between 4 and 5 mph. I would NOT go over 5 mph with it. We always planted at around 4.5 mph and had a nice crop.
The drum is ground driven so you can go as slow as you want - I planted a plot of sweet corn in first gear one year, came up beautifully and grew nice. Darn raccoons got all of it the night before I was going to harvest it... :evil:
garytomaszewski
05-02-2008 17:40:03
That would be the MAXIMUM speed.
Derik in ND
05-02-2008 17:45:08
 Re: 400 cyclo planter in reply to garytomaszewski, 05-02-2008 17:40:03
Thats what i assumed, but it doesn't say max, it doesn't say min, it just says: Speed.
Gary,kansas
05-02-2008 18:20:12
 Re: 400 cyclo planter in reply to Derik in ND, 05-02-2008 17:45:08
7 mph seems a liitle fast, I agree on the 4.5 to 5 mph. I used a 400 on 1000's of acres and found out if I crowded it, especially on rougher ground, the seed would fall out and the stand could be short. Good planter but I think the guy recommending 7 mph was in perfect conditions. Keep your RPM's up and you'll do great.
Allan In NE
05-02-2008 18:03:14
It says that for a reason.
Make sure the drop shoes are sharp and the deflector chains are in place; they wear the bottoms.
Allan
