Farmall A leaky axle
RJV
05-03-2008 04:36:37
Just bought a super A that apparently has been sitting a while. Now that Im using it, major leak at the front seal and the right rear axle. Im new to the super A tractor. My questions are... How do you know how much fluid should be in the rear trans axle? I assume that you would fill it at the top trans cover plug. I measured the oil through this plug and when I hit bottom, I have 3 inches in the transmission. This is the oil thats coming out of the rear axle, isnt it?
The oil is coming through hitting the brakes, so this is the inner seal, isnt it? That means I would have to take everything apart, final drive gear assymble, long axle tube, to get to the Inner seal. Correct? Am I going to have to replace the outer seal also when I disassemble?
What manual is out there that can guide me through this. I bought the A service man. and am very disapointed. Its about 65 pages and not very complete. There is nothing in there that mentions how to replace the seals.
I am leaking very bad. When I park it I have a puddle about the size of a grapefruit. It needs attention. Any help or advice on this project is apprecieated
Thanks
Ron
RJV
05-04-2008 02:58:10
 Re: Farmall A leaky axle in reply to RJV, 05-03-2008 04:36:37
Thanks for your input
Rootsy
05-04-2008 05:50:44
 Re: Farmall A leaky axle in reply to RJV, 05-04-2008 02:58:10
5 quarts in the rear end w/o PTO and 1 3/4 Pints in each final drive.
Believe you add a quart to the rearend if you have a PTO.
If the rearend is leaking then it is the diff support seals. If it is leaking near the brake bands (especially the right side) and not coming out of the weep hole near the rearend then the top final drive seal is leaking.
RJV
05-04-2008 06:59:44
 Re: Farmall A leaky axle in reply to Rootsy, 05-04-2008 05:50:44
Where do you fill the final drive? Is there a level plug? How do you know there is 1 1/2 pints in it? I cant find a any plugs for the final drive.
Thanks for all your help.
Rootsy
05-04-2008 18:13:01
 Re: Farmall A leaky axle in reply to RJV, 05-04-2008 06:59:44
grab your 1/2" drive ratchet, crawl under the tractor. On each side (each final drive) on the front inside just above the tin bottom cover there is a pipe plug.
fill with gear oil until it comes out of the hole.
gene bender
05-03-2008 06:35:06
Sounds like its pretty near full the level plug is behind the left brake rod at the front of the tranny. Which side is the leak as it could be from the final drive as there is a seal on the tranny and one on the final drive.
riverbend
05-03-2008 06:23:39
I don't have a Super A, but on my Super C, there is a small pipe plug on the right rear of the transaxle housing that allows you to check the oil level. When oil runs out, you have enough.
On the topic of manuals, they all have strong points and some weak spots. The IH Service Manual will be more complete, but they still expect you to be familar with these tractors. I&T manuals can give a little more coverage on the transmision, but they do rely on the 'results being intuitively obvious to the casual observer'. A parts book is a good resource for seeing how (and what are ) all the little bits go together. It also makes ordering parts much easier. The Operators Manual covers where everything is and what you need to do to mantain the tractor. Between all of them and a little advice here, you can usually figure out how to fix anything.
As far as the leak goes, you might need to take everything apart. If the problem is a bad bearing rather than just the seal, chances are other bearings may have been damaged too. The good news is that parts are available and the tractors were designed to be worked on and fixed.
Greg
RJV
05-04-2008 02:52:23
 Re: Farmall A leaky axle in reply to riverbend, 05-03-2008 06:23:39
When I opened up the level plug, about 1/4 - 1/3 cup of fluid came out. I know when tractors sit outside, water will get in through the gear shift. Do you think I was leaking out through the axles because it was over full?
I drained the thick, brownish stuff out and filled it with new gear oil to the proper level. I will be currious to see if it still leaks.
RJV
05-03-2008 10:17:05
Thanks for telling me about the level plug, Thats the first step. I think I will buy a parts book also.
