H Carb
GordoSD
05-03-2008 19:12:13
I'm trying to get the throttle governor screw out of an H carb. It's FROZEN in there. 3 days in the carb pot, another two days with PB all over it. No Luck. Don't want to twist it off. Any danger in getting out the blue wrench, the little propane one, out and heating up the upper body? Shaft has the old bronze ears. It was missing the inlet filter assembly. The little brass fitting and screen. No problem, IH has it, $17.50!
Gordo
GordoSD
05-04-2008 15:03:05
 Re: H Carb in reply to GordoSD, 05-03-2008 19:12:13
I did what you said, when I heated the upper body up, it came right out. Thanks to the Bernz O Matic and you guys!
Gordo
RustyFarmall
05-04-2008 04:26:24
A torch can be your best friend when working on those old cast iron carbs.
Janicholson
05-03-2008 19:19:59
Heat the screw (not red) then let it cool about 5 or 6 times. then when cool, heat the body just hotter than smoke a bit of wax when touched. then try turning (in nd out) just a tad. if it seems to move, then PB blaster, and some more time, it will allow the lube to get in.
JimN
