two questions
tn terry t
05-04-2008 06:51:44
someone refresh my memory please on a 123 engine do you have to take the front timing cover off to replace the crank seal? doesnt it go in from the inside tward the outside? also anyone have the number for the repair wear ring that goes on the crank pulley ? i know the seal # is 49177-D just cant find the wear ring number
El Toro
05-04-2008 08:42:48
 Re: two questions in reply to tn terry t, 05-04-2008 06:51:44
You can get the speedi-sleeve and the new seal at any Napa store. Case/IH may have them too. Hal
DRC
05-04-2008 08:27:54
Yes, you must take the timing cover off. The seal presses in the inside of the cover.
I don"t have the # of the Speedy-sleeve, but you could either to mic. it, or I"m sure someone else may post it.
Doug
