Schwartz Wide Front Identification
CtryBoyInMT
05-04-2008 18:17:54
My Farmall has a Schwartz on the front and was hoping someone knew how to decode the model number.
It's DU 460 56
In all honesty, for being all OE (circa 1959) parts except bearings, it is still working great! I did notice that the tie-rod ends are getting some slight play and thought I would just keep an eye out for some replacements, if I stumbled upon them at an auction.
Any help would be great!
Thanks!
CtryBoyInMT
05-05-2008 17:47:49
 Re: Schwartz Wide Front Identification in reply to CtryBoyInMT, 05-04-2008 18:17:54
Thanks all,
I appreciate all the info.
I am just going to buy new when I need them.
RustyFarmall
05-05-2008 04:22:10
Any parts you need for that Schwartz are readily available and can be on your doorstep in about three days or less. New tie rod assemblies are less expensive than buying the individual parts.
Email is open.
jimmyjoe in MN
05-05-2008 04:20:59
The tie-rod ends on my schwartz wide front are adjustable. Just take out the cotter pin and screw in the end with the screw driver slot.
Tim Shaw
05-04-2008 18:33:12
That's the number for the standard front end. HDUH460 is the number for the heavy duty model. Parts for Schwartz front ends are available from an A&I dealer.
CtryBoyInMT
05-04-2008 18:19:28
 Re: Schwartz Wide Front Identification in reply to dougie75, 05-04-2008 18:17:54
This crack smoker here forgot to include that it's a Farmall 460 so the 460 part is obvious.
