Farmall 140 valve cover retaining bolts, what type?
rdragoo
05-05-2008 08:59:10
Does anyone know what type nuts are used on the valve cover studs. It looks like they would need to be tapered in order to match the sheet metal and keep oil from seeping out around the studs that hold the cover down. Either that, or they had a fiber washer underneath the nut that provided sealing. Mine obviously has the wrong nuts on it. It's a 1974 key start 140. Thanks to the group.
Randy
1fortyfanatic
05-05-2008 19:06:44
 Re: Farmall 140 valve cover retaining bolts, what type? in reply to Dave Wells, 05-05-2008 08:59:10
That's right, it was a brass compression washer! Not a brass nut. Looked alot like a grommet.
Dave
Haas
05-05-2008 18:38:33
 Re: Farmall 140 valve cover retaining bolts, what type? in reply to rdragoo, 05-05-2008 08:59:10
I believe the nut is a standard fine thread 3/8 inch. That would be 3/8-24 NF. There is a special brass or copper washer that is supposed to go under the nut. The washer is IH part number 62866D or 357374 R1. As Hugh said, don't over tighten, or you may deform the valve cover.
TheDurk
05-05-2008 17:16:29
 Re: Farmall 140 valve cover retaining bolts, what type? in reply to hector gemme, 05-05-2008 08:59:10
Just took a look at my 1966 140--definitely stock in that area; I've owned it since new. As Hugh said, just a regular hex hut over split washer. Cover does not look "taper-friendly" around the stud. Maybe something has been done to your cover? Or maybe it is aftermarket?
1fortyfanatic
05-05-2008 16:55:19
 Re: Farmall 140 valve cover retaining bolts, what type? in reply to NawlensGator, 05-05-2008 08:59:10
rdragoo said: (quoted from post at 16:59:10 05/05/08) Does anyone know what type nuts are used on the valve cover studs. It looks like they would need to be tapered in order to match the sheet metal and keep oil from seeping out around the studs that hold the cover down. Either that, or they had a fiber washer underneath the nut that provided sealing. Mine obviously has the wrong nuts on it. It's a 1974 key start 140. Thanks to the group.
Randy
I remember that they seemed to be brass, and yes there is a special washer for them. My mind is drawing a blank, but I seem to recall that they were some type of high heat plastic. But it seems to me that a fiber, cork or other washer would seal them up just fine.
Dave
Hugh Mackay
05-05-2008 16:05:40
rdragoo: I saw your question this morning, been 4 years since I had the valve cover off my 140. I don't remember anything special about those bolts, however I intended to look today and forgot. I know my SA and 130 have bolts in the head with a threaded top and 2 nuts hold the valve cover down. I believe my 140 is the same. I do know if you draw those down too tight you will recess top of cover around bolts. If that has happened they will leak.
