3 point hitch for 2404
doug f12
05-05-2008 14:28:38
i have a 2404 with no 3 point no on housing is 375576r2. i also have a 504 farmall witha 3 point on it. the no on that tractor housing is 3775576r1 can i use this on my 2404 . the 2404 has place for rock shaft but does not have it. the 504 is all there. am no mechanic so need help to find out if this will work thanks for any help
JSharp
05-06-2008 10:09:27
 Re: 3 point hitch for 2404 in reply to doug f12, 05-05-2008 14:28:38
Looking at the exploded parts diagram on caseih.com it appears the top housing number is the same for both the 404 and 504. There do appear to be some differences in some of the other parts though.
I'd look there and go through the parts for the 3pt assembly one at a time to see how much would transfer from one to another. I know for sure some things like the lower link arms are different. Good luck finding any for a 404. I had to make some work that were a little shorter. It's all I could find.
hughb
05-05-2008 15:23:15
My 1963 2404 has the 3 pt hitch. The # on the hitch is 375576R1. Does this help?
