washers under nuts for head++
poorfarmall 1
05-06-2008 16:14:45
pulled head on distilate h full of crap on top pistons motor woulnt crank spins free now there were only 3 washers under 3 nuts holding head on.do i need more &if so where to get? also wondering if just any auto machine shop can rework this head? thanks for info!
riverbend
05-06-2008 19:42:33
 Re: washers under nuts for head++ in reply to poorfarmall 1, 05-06-2008 16:14:45
Three washers are correct. ANy decent machine shop can rework the head. I have Jim at our local Harley shop do my head work. Have them check it for cracks too.
Greg
poorfarmall 1
05-07-2008 02:06:28
 Re: washers under nuts for head++ in reply to riverbend, 05-06-2008 19:42:33
thanks jim iam not sure which 3 studs get washers & why only 3? any body know
Theman
05-08-2008 05:32:05
 Re: washers under nuts for head++ in reply to poorfarmall 1, 05-07-2008 02:06:28
The studs that take the 3 flat washers are the ones that are closest to the centerline under the rocker arms. There are steel sleeves pressed through the water jacket of the head casting and these washers spread the clamping force of the nuts over a larger area to hold sleeve and cast iron around it stationary.
From a manufacturing standpoint, drilling the head and inserting sleeves would produce better overall results than having troublesome core and casting defects.
poorfarmall 1
05-07-2008 02:13:41
thanks greg
