400 still shaking
littlemackinawfarmall
05-06-2008 18:12:12
Okay slight vibration I mean would not even call it a vibration just a tractor when it is sitting still idle to full throttle. Rolling down the road not much of anything till you hit 5th torque forward full throttle than get your martini shaker and hold on...Vibrates as bad as the old quarter vibrating beds...could this just be in the tires or something easy...
05-07-2008 11:26:38
 Re: 400 still shaking in reply to littlemackinawfarmall, 05-06-2008 18:12:12
its not the wheels....they are running straight no wobble but will tighten things up such as the u-joints and gear...the new wheels and tires was to counter the possibility that it was in the wheels and tires from lot rot flat spots etc
mkirsch
05-07-2008 10:56:10
You should be able to lean over a bit so you can see the front wheels. They are probably doing a shimmy-shake under there. New wheels won't help, only fixing the multiple wear points in the steering system will make a difference.
05-07-2008 07:54:10
okay so check sector gear..the front end runs straight if you let losse the wheel...i am gonna strip all the weights...and I have a set of hubs and wheels for a 560 that i was going to put on it so I may try that now also...
Brownie 450
05-07-2008 05:17:45
Sounds like the steering sector gear is loose on the upper bolster shaft. The nut might be loosened letting the front wheels/bolster shaft do a dance number. Our 450 did the same thing---had to replace the sector gear. Everything is tight now.
El Toro
05-07-2008 03:54:43
Check the wheel weight bolts for being loose too. Hal
Gary,kansas
05-06-2008 19:32:48
If you have the cast front hubs, check to see if the rims are mounted straight and all bolts are tight.
