F-12 Plow Pictures
Tom Fleming
05-07-2008 03:06:47
A couple of you guys have asked for some pictures of my F-12 plow setup. Here are some shots. If there are any additional pictures you would like, please let me know. First 2 are from the seller, when I bought the tractor and plow.
ps. I bought the tractor and plow this way, I did NOT select the paint scheme!!!!
third party image
third party image
third party image
third party image
third party image
third party image
rich4
05-07-2008 09:15:57
 Re: F-12 Plow Pictures in reply to Tom Fleming, 05-07-2008 03:06:47
Quite an elaborate setup, I'm sure the later CUB and A mounted plows evolved from this one.
Dave Allgire
05-07-2008 07:24:35
I've got one exactly like that that I've restored. I've also got an instruction/owners manual for it (copy). The date of the manual is 1937. It's quite the conversation piece. There was enough of the original paint left on some of the pieces so I could paint it the original colors. BTW that is a Farmall Tractor Plow No. 90 and it came as either a chain lift or a power lift version.
Steven f/AZ
05-07-2008 07:18:00
That is a neat lift! Didn't know anything like that existed...
Irv (Ia)
05-07-2008 07:01:11
I'm like Gary..never saw one of those before! I assume the left wheel chain provides the power for some kind of lift, but what's the wheel on the ground and the right side adjusting lever for?
Irv*
Irv (Ia)
05-07-2008 07:10:34
 Re: F-12 Plow Pictures in reply to Irv (Ia), 05-07-2008 07:01:11
Now that I kept looking at it, would that be how you set the plow depth? Also, is there and mechanism on there for the plow the detach if you hit something hard?
Irv*
ET
05-07-2008 05:21:16
The colter and clamp are the same as a pull behind plow of the same vintage. Do you have an operators manuel for that plow? I have a plow like that on my F12 and it is a sweet plowing rig, but I would like to find out what the wheel spacing should be when its set up for a 16" bottom.
Tom Fleming
05-07-2008 04:39:33
One note, you can see the coulter is missing. If anyone has one, please email me.
James Williams
05-07-2008 04:33:37
Tom,great picture,My neigbor has one like it but not as good looking
jimmy
Nebraska Cowman
05-07-2008 04:24:42
That's cool. You'll have to bring it to Plowday sometime.
IaGary
05-07-2008 05:08:03
 Re: F-12 Plow Pictures in reply to Nebraska Cowman, 05-07-2008 04:24:42
Never seen that type of mechanical lift before.
Never knew it exsisted.
