Rear Spoke Rims
david ofstad
05-07-2008 18:45:02
Where can I find a spoke rim for a farmall H?
jhb
05-09-2008 01:36:04
 Re: Rear Spoke Rims in reply to david ofstad, 05-07-2008 18:45:02
I tried selling a set of spoke hubs for an H with weld on 38 rims several times over about 2 years and finally junked them for their metal value. I was as low as 75 dollars. No one seemed to be interested. I hated to do that but no one responded. What is one supposed to do? I guess timing is everything. I finally sold an IH 46 twine tie baler after many tries. I have the payment but am holding it for an individual to pickup.
Zach Bouchard
05-07-2008 19:38:49
There not original on the H. You must be thining about steels that were modified.
jal-SD
05-07-2008 19:07:19
Is the spoke rim you are asking about cut-off steel? Those are the only spoke rims that I can think of. Some were cut off to take 36" rims & tires, we have a neighbor that has 36's on his and I've got one with 38's. You will probably have to find one from a salvage yard, so be carefull that you get the right size. (My $0.02 worth. jal-SD)
david ofstad
05-13-2008 06:49:42
 Re: Rear Spoke Rims in reply to jal-SD, 05-07-2008 19:07:19
Thanks for the replys. I figured they were not original because I couldnt find any pictures of an H with them.
