IH 574 Fuel Pump Issues
Ed Gore
05-07-2008 20:18:29
My IH 574 gas tractor has problems running. It will just die at random times. I suspect problems with the fuel system, but have completely cleaned out the lines from the gas tank to the fuel pump.
However, the fuel pump still has the original parts, and the rubber is worn, especially on the upper diaphragm. Is that enough to cause the problems with fuel flow to the engine? I can usually restart within a few minutes of turning the engine over, but its very annoying to not have constant operation.
Can someone tell me if there is a rebuild kit for this tractor's fuel pump?
If not, could I replace it with an electric fuel pump, and if so, which model would they recommend.
Or is there a specific model number for this fuel pump that I can purchase? My owners manuals don't list the part number.
I'm new to tractor ownership, and while somewhat mechanically inclined, am not a wizard.
Any help from this knowledgeable group is appreciated.
JimB2
05-08-2008 14:56:09
 Re: IH 574 Fuel Pump Issues in reply to Ed Gore, 05-07-2008 20:18:29
Hi, you said you cleaned out the lines from the gas tank but did you clean out the bottom of the gas tank? On the Diesel models the problem is usually at the outlets of the saddle tanks. Junk collects in the bottom of the tank and clogs outlets. My brother had the corps of a lady bug in his 684D's tank that caused the same problem until he took out both outlets and drained the tank.
JimB
Ed Gore
07-16-2008 16:01:21
 Re: IH 574 Fuel Pump Issues in reply to JimB2, 05-08-2008 14:56:09
Okay, Today I confirmed the problem is in the fuel pump by bypassing the pump altogether. I still can"t find a supplier for a replacement fuel pump or rebuild kit.
Any suggestions please????
