Spark plug hole "plug" for cleaning & painting
neblinc
05-08-2008 05:13:40
Any tips on what to use to plug the spark plug hole so I can clean out the spark plug cavity on my H. What size are the threads? Can I use a pipe fitting plug?
Randy
1fortyfanatic
05-08-2008 20:01:41
 Re: Spark plug hole plug for cleaning painting in reply to 658834, 05-08-2008 05:13:40
I like Rusty, Ron and the Theman's idea. Just some old broken off plugs, even if you have to seal the top with silicone or something. Especially when you consider wire brush or screw driver in there cleaning stubborn guck. No plastic plug has ever withstood me with anything sharp in my hand. Neither has my skin.
:shock: Dave
CNKS
05-08-2008 18:21:31
 Re: Spark plug hole plug for cleaning painting in reply to neblinc, 05-08-2008 05:13:40
18 mm threads, the holes are metric. Pull the head and clean the carbon off the top of the pistons while you are at it. Perhaps get the head redone. Less than $200.
Ron in Nebr
05-08-2008 09:30:57
I've always just taken an old set of spark plugs and broken the porcelain(sp?) off of them right above where the wrench flats are. The rest of the porcelain will stay in the metal part so no probably with them sealing the cylinder. Makes a handy little plug that's down out of the way for cleaning/painting etc.
neblinc
05-08-2008 06:21:56
I don't have too much in hydraulic stuff but I am sure my neighbor would have some of those plastic plugs.
Great idea!!
Thanks
Randy
RustyFarmall
05-08-2008 07:24:44
 Re: Spark plug hole plug for cleaning painting in reply to neblinc, 05-08-2008 06:21:56
I like the plastic plug idea.
Theman
05-08-2008 06:05:26
Standard 18mm spark plug (square) thread. This is not a pipe size. Threads will be damaged. A couple of options: -Destroy a used spark plug by breaking out the porcelain and JB welding or filling it with silicone. -Buy an anti-foul adapter of the correct size and do the same with it and save the used plug. -Stick a plastic dust plug in it that came from some hydraulic part or another - you are saving things like that aren't you?
gene bender
05-08-2008 05:46:04
I use corks that i bought at the flea market
neblinc
05-08-2008 05:22:31
That's what I have in there now Rusty, but I can't get in there with the wire brush to clean out all the gunk.
Randy
cannonball
05-08-2008 09:20:25
 Re: Spark plug hole plug for cleaning painting in reply to neblinc, 05-08-2008 05:22:31
go to hardware store or ac store and get a brush for cleaning copper tubing...
MAY GOD BLESS THE USA
RustyFarmall
05-08-2008 05:22:12
I just install a set of used spark plugs.
