Farmall 200 steering gear
Cody Butts
05-08-2008 13:49:57
I am 13 and restoring my first tractor it is a farmall 200 and it has a wide front end but at the worm shaft I have a leak (this is underneath the steering gear sitting upright) i am looking for some kind of kit or a fix solution the kit will need to have worm shaft seal, Gasket, Bearin cage cover gasket if you can find these individualy to that would be good
thanks cody
RED POWER
GA Dave
05-09-2008 18:40:48
 Re: Farmall 200 steering gear in reply to Cody Butts, 05-08-2008 13:49:57
Your Case IH dealer should have the parts. Other places also. See the post about the IH Planter for a link to their online catalog. David.
gene bender
05-08-2008 18:06:39
You should get an I$T manual. You need to block the front so you can remove the wheels and then the axle. Then you can take the steering sector apart and rebush and maybe the bearings need replacing. New parts to rebuild the steering sector will run around 50 bucks. When done with new seals and bushings it will be like new again.
Cody Butts
05-09-2008 14:35:31
 Re: Farmall 200 steering gear in reply to gene bender, 05-08-2008 18:06:39
where can i find the parts
