IHC 460-560
:RIVIR
05-08-2008 20:03:29
this farmall 460 has a poor engine (bad) and the wrecker just took in a IHC 560 that they a parting out, engine good, will the 560 282ci fit right in a 460 236ci, without complications, this could be my next winter project.
farmer_nk
05-09-2008 12:54:28
 Re: IHC 460-560 in reply to :RIVIR, 05-08-2008 20:03:29
The blocks are the same. Differant stroke in the crank is all. Just bolt on your 460 flywheel and rear plate to the 282. Very easy project!
RN
05-09-2008 00:45:02
double check bolt pattern at flywheel end - possible difference in 560 the 460 so might not fit. 460 was discussed in puller forum and bolt pattern noted as fittable to 300, Hs but not M and 560 drives unless dual pattern block was found. 560 and M blocks not to fit H drive which 460 developed from. RN
