130 transmission level plug
Mountaincabin
05-09-2008 02:28:51
The internal faces on the transmission level plug square drive are rounded on my 130. There"s enough plug showing that I can get a vice-grip on it, but before I bugger it up,
Two questions: 1. What was the original size of the square drive opening (not the plug size, the square drive) 2. Are these plugs still available?
Hugh Mackay
05-09-2008 05:43:05
 Re: 130 transmission level plug in reply to Mountaincabin, 05-09-2008 02:28:51
Mountain cabin: The fill to level plug must be 7/16 where square drive fits to remove it. I have 3/8 and 1/2 inch drive sockets, neither fit. 1/2 is too large and 3/8 is too small. I use a 2" long square key stock on mine, and it must be 7/16". I expect the plug is 1/2" pipe. Don't know about a regular hardware store plug, the end may interfere with brake activation rod. It definitely will rub on it.
gene bender
05-09-2008 02:44:34
Dont you mean filler plug by the shifter? Just take it to a plumbing supply whosale place or i can send you one give me the dimensions just to make sure we are talking the same one.
