Hydraulic fittings adapters for Farmall 350
Bongo
05-09-2008 05:30:13
I recently acquired a Farmall 350 with fast hitch and dual hydraulics. of course one spool is used for the fast hitch but the other ends are under the hood on the right side and have little metal caps over them. I took the cap off and was expecting to see some type of quick connect but what I found was slightly different than expected... basically had male threads and then flat face with some type of valve face exposed (a picture would be worth a thousand words here but didn't take one and the tractor isn't close by).
Anyway, it looked like they are stock fittings and I am simply interested in finding an adapter to make them compatible with current "pioneer" quick connects.
Where can I get adapters and what specifically should I ask for when I call?
Thanks.
Lance
P.s. This has probably already been answered but I couldn't come up with a search string that brought an answer.
El Toro
05-09-2008 07:52:45
 Re: Hydraulic fittings adapters for Farmall 350 in reply to Bongo, 05-09-2008 05:30:13
Your local Case/IH dealer may have the adapters
if that was a factory installation. Your local store that sells hydraulic fittings such as Aero Quip or Parker Hannifin that makes Pioneer quick disconnects if you can take one of the fittings or a good close-up picture they can probably come up with an adapter. Hal
