Question for Tractor Vet.........
CenTexFarmall
05-09-2008 14:40:29
I'm finding the limitations of my IT manual. Do you happen to know what IH specifies for torque for the ring gear/differential bolts on a Super M?
Also what should the clearance be for the PTO pilot bushing and the reverse idler bushings?
Thanks.
CenTexFarmall
05-09-2008 19:27:52
 Re: Question for Tractor Vet......... in reply to CenTexFarmall, 05-09-2008 14:40:29
Thanks guys for responding!
I'll mic the PTO stuff again. The reverse idler bushings are done though; little bits of metal embedded in them. Got new bushings sitting on the workbench!
D Slater
05-09-2008 17:21:40
New bushings sized to 1.237 to 1.238 in R idler.
0.908 to o.909 in counter shaft. Original ring gear type nuts with lock plates, 85 to 95 ft. lbs. dry threads.
the tractor vet
05-09-2008 16:09:48
Can't answer that for ya . When i am in doubt on bolt torque i use the Cat manual as they have a torque for all grades and sizes Course and fine thread. As to the clearance on the bushings can't tell ya here again don't know . Go by feel if it feels to loose then fix it . But keep in mind here that they run in 80-90W gear oil so they can be a bit on the loose side.
