Hyd steel lines
MAGMAN
05-09-2008 15:30:10
I have a blown steel pressure line on my 300 from the valve back to the seat. whats the best way to fix or replace or what ever. JON
CtryBoyInMT
05-10-2008 13:34:07
 Re: Hyd steel lines in reply to MAGMAN, 05-09-2008 15:30:10
Just about any hydraulic shop, worth anything, can fabricate a new steel line for you.
In fact, a trailer company (who mainly deals with air) made me a new one for my loader a few years back.
Any older timer hyd. guy can whip one out in no-time. Just bring all the pieces.
Brazing is proven to work, but why spend the time and just get a new line.
Duner Wi
05-10-2008 05:31:58
I brazed lines on mine. They vibrate and wore a hole in it.
MAGMAN
05-10-2008 05:05:48
I do not know I have never worked with hyd hoses before just quick connects, but there is a piece about 6" long missing where someone put a piece of garden hose on with hose clamps but it looks like it did not work , LOL its split. I have been looking on ebay for months and can not find any. I even asked a tractor junkyard and I guess its to small of a part they wont get back to me. JON
El Toro
05-10-2008 04:27:26
Could you replace them with braided hydraulic hose? They will withstand the vibration. Hal
Andy Motteberg
05-09-2008 20:59:09
That hydraulic line blew on my Dad's '56 300 a while back, the lines were very pitted so we just bought different ones off eBay. If yours are badly pitted, you should replace them, if it is just a hole or crack, you might be able to weld or braze it.
jimmyjoe in MN
05-09-2008 19:18:03
I brazed a 1/2 inch pipe coupling to the good pipe .
the tractor vet
05-09-2008 16:03:36
Well i have used two ways of doing this , (1) try and braze the hole , (2) Cut out the bad section and weld a 1/2 inch pipe coupler on each good section and replace with a high pressure hose.
