Farmall 450 IPTO
Stan in WI
05-10-2008 07:43:39
Trying to put differant IPTO in 450. What is the trick to lining up that shaft or do i have to remove the whole platform? Thanks Stan
Roger46
05-10-2008 15:35:40
 Re: Farmall 450 IPTO in reply to Stan in WI, 05-10-2008 07:43:39
I just put mine back in a 350. What position do you have the engagement lever in? If it is in the disengage position the input shaft may just turn as you turn the unit so it will never line up unless you are lucky. If the lever has the PTO engaged you can turn the PTO shaft and turn the input shaft to help spline alignment (Turns hard through the planetary gear system). They are heavy units and amazingly complex for what they do as I just rebuilt mine. Roger
Stan in WI
05-10-2008 12:06:21
Same unit but im sure the shaft is not the right angle to slide back together. there has to be a little slop there. thanks Stan
ejr-IA
05-10-2008 11:47:08
Pulled the PTO out of a 560 a couple times shoud be able to slip it in with out removing the deck.Are you putting back the same type PTO that you took out?Theirs different geaaring for the band or clutch type PTO's.
